Voyager engine 3.3 lts national takes to start
12 years 7 months before #39034 by manual-mecanica
B. day to all.
I got a V6 3.3 LTS, National, Mod 2001, it turns out that they changed the gasoline pump, they tell me to turn out of that, the cold truck bone in the morning with 3 llavazaos, but already working and if they turn it off for some reason they have to give it in 5 or 6 llavazos to start. Already starting the truck works at 100 ... the VDD ... I don't know what it is ...:(
something that they recommend me .... how to check gas pressure, or some air pacifier, ????
I am waiting for your comments
thank you very much
Salu2
12 years 7 months before #39059 by manual-mecanica
Manual-Mecanica response on the Voyager 3.3 LTS national theme takes to start
It happened to me in a C 1500 when replacing the pump the problem was that the pump was not eactly the same and had a valve as a precion release and downloaded, Czech wanted to be the same problem
12 years 7 months before #39069 by manual-mecanica
Ok. I'm going to see with the owner, since I got failing, to check that it is for the year and model.
In fact it is what I think and comment that a pressure of gasoline is missing.
thank you
12 years 7 months before #39079 by manual-mecanica
Eye friend because the one they sold to me went to the model and year brand and still did not correspond. It is better to compare it.
