Toyota Corolla Hydraulic Directorate 1996
12 years 6 months before #39196 by manual-mecanica
Toyota Corolla 1996 Hydraulic Address published by Manual-Mecanica
Greetings!
I have problems with the hydraulic direction of my car.
When I turn the crank, a slightly serious noise begins to sound. A few weeks ago they changed the creamyera, hose and hydraulic system pump.
He is not firing liquid and when I check the pump is fine with the amount of it.
I would like to know if the hose still has air (and if that is normal) or what can the problem be and how to solve it?
Thank you!!!
12 years 6 months before #39225 by manual-mecanica
Manual-Mecanica Response on the topic Hydraulic Directorate Toyota Corolla 1996
Hello, I had an equal anger in a Honda Civic and resolved the right -wing steering wheel and then the left is totally a form of purge attempt but of course with the car turned on and thus about 3 fields but in the first one the problem is solved ok
12 years 6 months before #39267 by manual-mecanica
The ideal to purge the system well is to lift the vehicle and leave the two front wheels in the air, and as C7 says, the bolter rotates to the right and to the left about three to four times or those that are nesessary, also check the status of the belt and verify that the pump is online with the belt and not displaced.
