2 cylidros failure in a Chevrolet
12 years 6 months before #39321 by manual-mecanica
2 cylidros failure in a Chevrolet published by Manual-Mecanica
Help gentlemen is a pleasure to greet you in advance I want to thank them for reading my message The matter is like that I have a problem with a 2004 Colorado Chevrolet of 2004 The problem is that two injectors do not work in low reboly but if I accelerate it at 3000 rpm. If they work, I change computer ... the coils of place the injectors of place the cranksensor and nothing always I fail and the scanner throws me p0315 which is the cranksensor according to my scan. But I don't know what to do more to do is an aid beating me :(
12 years 6 months before #39326 by manual-mecanica
Manual-Mecanica response on the topic 2 cylidros failure in a Chevrolet
Look first you gave 3 times contact the car, this is for him to gain when one changes the sensor, if it is not done, the sensor works correctly works a multimeter voltage in alternate and generates tensions of 2 V
12 years 6 months before #39479 by manual-mecanica
Thanks for your answer. I stop very lojica, provide the sensor and if you throw the voltage that you say only forgive ignorance as exhaus to program the sensor because for what I understand that I do not have thanks again for your prompt help
12 years 6 months before #39544 by manual-mecanica
The CKP generates that type of failures, I recommend replacing it
C3 Care Car Center
www.c3Carecarcenter.com
