TURBO DIESEL ENGINE RENAULT LAGUNA 1.9 99`
12 years 6 months before #39344 by manual-mecanica
Turbo Diesel Renault Laguna 1.9 99` engine published by Manual-Mecanica
I present my case:
I was walking with my Renault Laguna Turbo Diesel 1.9 99 'and suddenly went out as if I had turned the key to put out (he kept rolling). I tried to start, the engine revolved but it didn't turn on ... then (1 minute later) turned on, I made 100 meters more and the same thing happened again: from there I could not start it anymore.
A mechanic told me that it came out (because it was lazy) the gear of the injection pump is possible? Would you have to have done some abnormal noise? Well, I don't hear anything ... and then, already at home, every time I tried to start the starter, it was all normal noise, only the engine did not start. The curious fact is that I stop, I could make it start and make 100mts more, and it came back ...
On the other hand, the gear of the injection pump goes with the distribution strap or with that of the air conditioning? Because he says that is why the engine stays out of his point, and that there is now a problem with the valves.
I await your comments, thank you.
12 years 6 months before #39388 by manual-mecanica
Manual-Mecanica response on the topic of Turbo Diesel Renault Laguna 1.9 99`
It goes with the distribution and if the valves are broken when the point is skipped, something is always heard on occasions only feels strange, if it were Camon Rail, the problem could be more things is that without looking or hearing it is difficult to help you help you more than answer what you ask us.
12 years 6 months before #39587 by manual-mecanica
Hello, apparently, what happened to you is that you cut the distri strap.
