change of tension in ECU DE MOTOR IVECO 10.3
12 years 6 months before #39534 by manual-mecanica
Tension change in ECU DE MOTOR IVECO 10.3 Published by Manual-Mecanica
Estimated mechanics and associates, I have the following problem, I have a cane harvester with Iveco Motor 10.3 Lts Cursor 10, the engine was damaged and for repair cost Food 12 or 24 volts, for me it is almost clear that every PLC or CCU has a vote rectifier with an important range of variation, but, I am not sure, if someone can give me a clue, it is appreciated.
Thank you.
12 years 6 months before #39554 by manual-mecanica
Manual-Mecanica response on the topic change of tension in ECU DE MOTOR IVECO 10.3
Friend if the control unit comes with the new 12 volt engine then it is twelve volts if you were 24 then 24 I think.
