GOL POWER 2004 AIR CONDITIONING
12 years 5 months before #39677 by manual-mecanica
GOL POWER 2004 AIR CONDITIONING PUBLISHED BY MANUAL-MECANICA
Hello friends, I am new in the forum, I have a consultation for Acerles and I thank you who can help me, I have noticed that the belt squealed me every time that turned on the A/C as we were in winter I did not give importance but I saw it when I turned it on so that the entire air system was worked a little, well now the summer came I decided to change the belt, I changed the water pump that I had a bit of the axis. The question is that it has everything new but the belt continues to squeak even without turning the air when the car is cold, one that warms up but what most caught my attention that when I turn on the clap Inside the air cools, now when it is at low rebolautions this happens if I grab the route and give it it and the air is perfect when it slows it empies all the chillido back it has me crazy it already has everything new if someone can guide me or give me some idea that it can be. Greetings are appreciated
