You can tell me that Motor Motor IC VALVULA IN DAEWOO TACUMA 2002 and if they have the repair manual thanks I have a problem with the minimal one turns off the engine
Good morning after information search, it found that this vehicle has an electronic acceleration body so it does not have the IAC, I only have to check that all this clean and a fixed issue. thanks for everything.
