CHEVROLET COMBO (PETROLERA) NO PART
12 years 5 months before #39773 by manual-mecanica
Chevrolet Combo (Petrolera) Not part published by Manual-Mecanica
Well to the workshop where I work we do not have scanner
then we have reviewed it like this ... First we thought it was a battery thing that is not ....
It has oil
we thought it was the incondent spark plugs that were bad and we changed them ...
but I did not start
later we sent to check the injectors but they are all working perfectly ....
Then we saw the pressure of fuel in the rail and everything works perfectly .... start them ... some suggestion that it could be ... I hope your answer see you chau
12 years 5 months before #39774 by manual-mecanica
Manual-Mecanica Response on the topic Chevrolet Combo (Petrolera) does not part
I would like to know if it marks witness on the board and if the engine turns because the pump filter (empty and does not inject) can be dirty)
12 years 5 months before #39775 by manual-mecanica
For what the witness light does not turn on ... the engine revolves ... we change oil filter too ... and we verify that no piston was stuck ...
12 years 5 months before #39781 by manual-mecanica
Hi Onisan
verifies if fuel is reaching the injectors when you start and compression of the machine.
Miguel
12 years 5 months before #39787 by manual-mecanica
On the fuel pressure we verify it with another mechanic, since it did not have many tools it released the nut of the injector connection at the time of making the system air, and it came out too oil, the injectors were also checked and are in very good condition,
