Very good good I write this lines to see if there is a solution to the problem that is killing me, is that my FPDM and rap burn from these I do not replace, the question is that vehicle could adapt these pieces? or what could it be done?
For those denominations I don't know what you mean, I think you mean the fuse box ... that by factory default is usually broken internally .... leaving the useless vehicle. This switchboard can be repaired by someone who has knowledge of electronics, since this problem is that the welds of the printed circuit skid.
Thank you very much for answering, to what I mean and I was investigating those components are the first one is the gasoline pump controller and the second the alarm and security controller, to which I go in particular is if anyone knows that another vehicle can be adapted since I ask the repetitioners of Ford of my country and they told me that they are already discontinued that you can do
