Ford transit 2.5 does not start
12 years 5 months before #39872 by manual-mecanica
Ford Transit 2.5 does not start published by Manual-Mecanica
Hello I have a Ford Transit Ke has been stopping a year and when I want to start it it costs a lot does not reach the injectors but the diesel filter is full that I can do thanks
12 years 5 months before #39878 by manual-mecanica
Manual-Mecanica Response on the topic Ford Transit 2.5 does not start
First replace the fuel, since if it takes a long time stopped, it can be deteriorated. Then replace the conmigible filter, as it can be clogged due to having been stopped so much time that the sediments have clogged them. Check that it comes to the Imjector pump, and that it leaves this with sufficient pressure, loosening the inlet tubes to the injectors, approved this same action to purge the fuel circuit (the broken injection pump can have). Check that the injectors' leftover tubes are not cracked, since it could take air out there, and put a good battery. If the transit is of electronic injection, disconnect the cables from the injectors to purge it, since these are very delicate.
12 years 5 months before #39904 by manual-mecanica
Injectors does not arrive Gaasoil
12 years 5 months before #39908 by manual-mecanica
Good
to know if your problem is pump pressure tries to turn it on with starter (which is a pressure solvent boat ... thiner) and if you turn on then you check the pump ... Check that way and comment;)
