Good morning, when I press the accelerator pedal the vehicle does not respond well, if the bottom floor is heard the roar of the acceleration but the vehicle has no impulse. Could it be that the acceleration guaya needs to be changed?
I understand that when accelerating, the engine accelerates, but the vehicle does not move as it should, so if the pedal is pressing, the acceleration of the engine is equal and equitable to said pressure, it may be that the vehicle does not move equally due to a problem in the clutch system, which this skates.
