PEUGOOT 306 HABITACULATOR FAN
12 years 5 months before #39948 by manual-mecanica
PEUGOOT 306 HABITACULO FAN PUBLISHED BY MANUAL-MECANICA
Good afternoon everyone, I've been looking for solutions for a couple of days and I can't clarify, my 306 fan has stopped throwing air, the other day turns off the engine having left it in the highest position and nothing else was known. It does not respond, I have changed the fuses under the steering wheel and nothing. I have lowered the workshop manual and I can't find anything. TB I have looked under the glove compartment and the only thing that I have achieved the headache for being from the setback, I have not known that I had to check. Someone can help me with what I have to do, where to look or remove, I don't know if the fan has a resistance under the glove compartment or the only ones are the ones I have already reviewed, greetings and thank you all in advance.
12 years 5 months before #39957 by manual-mecanica
Manual-Mecanica Response on the PEUGEOT 306 room fan
Hello, having if this is useful, I have a Peugeot 306 Sedan TD and from time to time the fan fails, what I do is disconnect the fan switch and with a screwdriver or some pliers press the terminals that go to the fan and work again the fan goes on the side of co -driver Tests if current arrives to make this check you have to put the contact, you will tell if you solve it, I hope I have helped you
greet
12 years 5 months before #39958 by manual-mecanica
You have the burned fan connector. Clean the connector
12 years 5 months before #39961 by manual-mecanica
I sign up everything and as soon as I have time. To clean the connector I have nothing but pull it to release it and a rag with alcochol right ?? or it is advisable to use some product. Thank you very much for your answers
12 years 4 months before #40310 by manual-mecanica
I have tried to get the 2 connectors that go to the fan and none of the 2 seems burned, I have cleaned them anyway and still does not work, the heating works comes out, but not the fan, will it have to change this? Greetings and thanks
