Hello, I have problems with my 2002 Furgon Partner. He started tarnishing the windrisa, and then I frame lack of water, when I realize I had all wet. The issue is that I do not know where that water comes from, the hose that is in sight is healthy, and could not disarm where the heating radiator is located, but it does not fit where to disassemble it. Does anyone have an idea of how it is done?
That happens when the heating radiator is damaged. On most vehicles it is enough to disassemble the glove compartment and you have access to the radiator, which is usually next to the heating fan. to disassemble the part of the board that is needed
It is correct what Armando says, he makes a bridge between the hoses, but in that vehicle the hoses enter with a plastic coupling and to make the bridge to cut them, if you do it do not ppodras to join them again, that radiator they sell it but it is expensive and there are no alternatives, the other problem schenses that radiator in your vehicle goes in the middle of the console so it is necessary that it is necessary to disassemble.
