Light Battery Mercedes Class A
12 years 4 months before #40116 by manual-mecanica
Light Battery Mercedes Class A Published by Manual-Mecanica
Hello friends, I had a load problem in a Mercedes Class A, which after extracting the alternator and replacing the regulator I have partially solved, since it already loads perfectly. The problem is that I cannot turn off the light of the picture I can't get it on .... I have reviewed all the connections, and the load is bore ... if someone can help me.
12 years 4 months before #40131 by manual-mecanica
Manual-Mecanica Response on the topic Luz Bateria Mercedes Class A
It could be that if the regulatory box is not the cable that carries the signal the pilot light is not working properly or that this cable has some inperfect.
