yellow oil level in Toyota Corolla
12 years 4 months before #40149 by manual-mecanica
Yellow oil level light in Toyota Corolla posted by manual-mecanica
Because yellow oil light on a Toyota Corolla 2.0 TD 2005 is caught while the oil is level in maximum and all filters have changed
12 years 4 months before #40157 by manual-mecanica
Manual-Mecanica response on the yellow oil of oil level in Toyota Corolla
The sensor may be failing and make that threat or that when the cold oil is condensed and it is turned to the temperature and go out
12 years 4 months before #40166 by manual-mecanica
The oil level light is turned on when it is really hot and if it were the sensor you could inform me exactly which one that would have to change and if you have any idea of ​​the cost of that piece. Thank you so much.
