Corolla 90 motor failure
12 years 4 months before #40233 by manual-mecanica
Corolla 90 motor failure published by Manual-Mecanica
Good, about two months ago I bought a 1990 Toyota Corolla and I have a problem in the engine, it is stable in minimal but when making the exit does not raise! As if the obstructed gas filter were, I already changed the filter, clean injectors, check spark plugs and their cables and I no longer know what else to do.
I would appreciate the help.
12 years 4 months before #40276 by manual-mecanica
Manual-Mecanica response on the topic failure Corolla 90
Check that the spark is strong and blue if not the problem is the coil
12 years 4 months before - 12 years 4 months before #40352 by manual-mecanica
You could check the progress degrees
the Toyota Corolla from 87 to 92 Motor Code 4A-F, they carry 10º If you give me the motor code I can give you more data.
Latest edition: 12 years 4 months before by .
