Failure at Hyundai Terracan 2.9 Cdri Diesel
12 years 4 months before #40242 by manual-mecanica
Failure at Hyundai Terracan 2.9 CDRI Diesel published by Manual-Mecanica
Friends, I have a Hyundai Terracan 2006 CRDI 2006 2.9 to Diesel, when I accelerate a lot and move with the vehicle when I arrived at 2200 RPM, a check -in failure comes out from time to time, with the scanner the P0100 and 1119 fault comes out, which correspond to the EGR valve and the fuel system, which I must perform, an injector cleaning, change the valve. When I accelerate without walking, no fault comes out even when up to 4000 rpm
thanks for your answers
12 years 4 months before #40245 by manual-mecanica
Manual-Mecanica response on the subject fails at Hyundai Terracan 2.9 CDRI Diesel
Hello, try to change the fuel and air filter, then see the possibility of cleaning the EGR and leaves the injectors for the last
12 years 4 months before #40249 by manual-mecanica
In many diesel vehicles this failure is mainly due to the valve failure that the EGR activates, I suggest you change it.
11 years 11 months before #42364 by manual-mecanica
I have that same failure in my Terracan 2.9 and I have not been able to find the problem, mine is 2002.
11 years 11 months before #42365 by manual-mecanica
EGR Estavalvula operates from Movimineto and this condition is with the VSS.
The fuel code is linked to the VSS since it has as its function the temperature of the combustion camera through the EGR and as it does not work it does it with greater injection.
