Purposed problem brakes
12 years 4 months before #40254 by manual-mecanica
Purgated Book Problem Published by Manual-Mecanica
Hello, here I am again ... Well I tell you, I have changed the chocolates and shoes to an R-5 of a colleague and all that has gone well ... I have an autojuste system and I had to buy the little pitch because I did not have it ... Well the problem comes now, after riding it everything I set out to purge the brakes and I am not able to remove the air from the circuit ... I have proven that all the ropes are well closed. leaks (unless I see, and I assure you that I am looking good ..), the fact is that I have been pumping and I always come out of air ... I tell you how I do it ... I have the tank of the brake fluid pump open and full to the top of liquid .. Empieza for the wheel farthest from the pump, a friend helps me pumping, as soon as I say the pedal I say. Seconds and I close it again, then it is when my colleague releases the pedal, and then pump again ... I don't know, I think something must be escaping, because I have purged brakes other times and it has not cost me so much to take out the air ... I need a luza that enlightens me ... hahaha..Joder, well, if someone can throw me a cable because oleh
12 years 4 months before #40295 by manual-mecanica
Manual-Mecanica Response on the problem Purgated Brakes
There is a way that never fails unless there is another problem.
Purge to setbacks, beans the potharm and with an oilingeringuilla or something similar and a 6 mm inside sleeve you put it liquid by the horger until it comes out through the glass. I guarantee that all the air comes out. Salu2
12 years 4 months before #40297 by manual-mecanica
Look at some occasion I spend something similar in a tsuru and what I did was this I leave the link of the video and I hope it helps you
