Change time strap
12 years 5 months before #40293 by manual-mecanica
Change time strap published by manual-mecanica
Hello colleagues and they changed my belt to my golf and now the car has problems, almost without force comes as at the first speed and then I am matched with the help of the mechanical manual try to put it in time but it turns on at the minute it went out and now it does not turn on it does not come from the coil ... what could have happened ???
12 years 5 months before #40298 by manual-mecanica
Manual-Mecanica response on the subject changes time strap
I need more vehicle information as a year and displacement.
Greetings,
12 years 5 months before #40305 by manual-mecanica
mmm ... If you go but do not start or go?
12 years 5 months before #40306 by manual-mecanica
Look at the truth is that the detail of your car began by changing the xque band did not synchronize the gear that moves the distributor but aorita that you say that your car has no spark from the coil you have to approach BARIAS TESTS also to help us if you gave us more information as they mentioned above but the first thing is Checar if in the harness of the coil depending on obviously. A trial lamp in addition to being a distributor when you turn when you go through the hall effect of the distributor since if the effectiveness does not turn does not send the pulses for the spark but well I start x that in addition to helping us with more information about your car
