How much to charge in mechanics Diesel Mexico ..
12 years 4 months before #40315 by manual-mecanica
How much in mechanics Diesel Mexico .. published by Manual-Mecanica
Labor:
Truck or trailers trash ..
Injectors replacement per piece ..
Motor brake calibration
Head removal for inspection
replacement of head packaging ..
motor repair (although only replace a shirt or some dance piston) is charged for opening the engine, right?
Remove camshate for inspection ..
valve calibration (use of lainas)
injector calibration .. (use of lainas)
gear replacements (Bull Gear, crazy gears or mediators .. (requires removing accessories and cover bands
) The labor costs varies too
: Pmuch: Cheer: .
12 years 4 months before #40363 by manual-mecanica
Manual-Mecanica response on the subject how much to charge in Diesel Mexico mechanics ..
In Mexico I do not know but in Spain the workshop time is between 30 to 50 euros. It doesn't matter diesel, gasoline or repairing a stuck lock. By the network you will find an autodata autodata program in the approximate repair times.
Example: Renault Laguna Change Correa Distribution 4h.
Another thing is that you entertain it faster and decide to reduce the customer.
