Nissan 89 Motor Z24 does not turn on
12 years 4 months before #40316 by manual-mecanica
Nissan 89 Motor Z24 does not turn on published by Manual-Mecanica
I have a problem with my Nissan model 89 engine z24 8
spark
plugs it
turns The problem of gasoline pump
12 years 4 months before #40322 by manual-mecanica
Manual-Mecanica response on the Nissan 89 Motor Z24 does not turn on
Check the coolant temperature sensor. In the Nissan until 94 it is a communication that start well in cold and hot does not start your sensor has been damaged and the resistance is very low so your failure is unlike if it was disconnected, this sensor for the fuel mixture is vital.
12 years 4 months before #40495 by manual-mecanica
Hello good day, perhaps you should check the pressure of gasoline I had a similar poor poble and it was popular with the pressure of gasoline
