Checar crankshaft positions Opel Astra ??
12 years 4 months before #40371 by manual-mecanica
Checar crankshaft positions Opel Astra ?? Posted by manual-mecanica
Hello. As it can be tested if the crankshaft position sensor is good or not, it is hall type (3 -pin connector, food, earth and signal). The car is paying or costs to turn on or grab RPM.
greetings
12 years 4 months before #40452 by manual-mecanica
Manual-Mecanica response on the topic Cecar Sensors of Cuñal Position Opel Astra ??
You need an oscilloscope, peel the signal cable a little and if it is okay, it will give you a ram -shaped graph (square line line).
12 years 4 months before #40457 by manual-mecanica
You can do the test with a diode, the connection will depend if it has a barnable earth then you connect the positive of the diode to the fixed positive and the negative of the diode to the variable negative and to flash when you give the contact if it does not do this bad, but eye to that vehicle the module of teaching or the coil is spoiled, the sensor does not sell it only sell the complete distributor.
12 years 4 months before #40475 by manual-mecanica
Well x There I did the SGTE Test:
Check feeding tension 11.75v approx, medium voltage between signal and earth ground, with the screen in front of the hall, connected and open contact 11.72v and not faced 0.06v, by there I read that the 1 ° value must be between 3-8V. Now the TB Media coil was inside the range, I need to see the module, all this according to Autodata. It is hard for him to have strength and in principle pull black smoke, TB suspected of the MAP.
12 years 4 months before #40570 by manual-mecanica
Good compi, so you comment more than the impression that you are under fuel pressure, did you check the pressure for doubts? In addition, if it were the ignition module or the MAP sensor should turn on the motor fault witness. Question.
