Problem with an automatic change ZF5HP19
12 years 4 months before #40372 by manual-mecanica
Problem with an automatic change ZF5HP19 published by Manual-Mecanica
I have an A6 of 99 in the workshop with ZF 5HP-19 change.
The problem is that by stepping on it is revolutionized and does not go.
I have the vag-com and I don't get any error code in the gearbox.
If someone had this problem and the solved would be very appreciated, I would spend information.
12 years 4 months before #40390 by manual-mecanica
Manual-Mecanica response on the problem with an automatic change ZF5HP19
Did you check the transmission oil level? .. And if you have done it as you do with the engine running or stop? Have you made a filter change to the automatic box?
