Passat oil pressure
12 years 4 months before #40509 by manual-mecanica
Passat oil pressure posted by manual-mecanica
My car marks the lack of oil pressure and I did the impossible xfa tell me to really make it urgent
12 years 4 months before #40517 by manual-mecanica
Manual-Mecanica Response on the Passat Oil Pressure
Hi, you know you must put more information about your car to be able to help you, what year is it, and what engine does it have? Almost all Passat must have 30 PSI of oil pressure at 2000 rpm,
(2 bar 2000 rpm) If you turn on the oil focus you must put an oil pressure tester to see that you really do not have a pressure and if in the tester you always mark you press you then it is a problem of the oil pressure bulb. greetings
12 years 4 months before #40545 by manual-mecanica
I agree with Apollo11 ​​more information is required to be able to give you more options so much than what you have done that you have checked and other things can be a problem of pressure bulb under flow due to duct covered due to lack of service or because the car is heated and the pump code
is
plugged
12 years 4 months before #40547 by manual-mecanica
If you have 100,000km Drag Fall Oil Pump
12 years 4 months before #40550 by manual-mecanica
Hello friends before, I thank you for how to help you look at the situation, this is a Passat 2004 20 Valves 1.8 turbo has 109000km, I rectified the engine and oil failure of oil failure after k will rectify it because it bought all new pump oil washed Carter everything as a new I had a week pulling slowly now another vz I get lack of precion precion understanding vulvo original vulvo be the work of the rectifier
