Hello, I have an automatic Ford Explorer year 97 4x4 Motor 4.0. Benchinera My problem is as follows:
Changes P, N, D, D1, D2 work perfectly, Péro when passing the setback does not work. The light of the O/D blinks intermittently on the board when putting the change R. This began to happen after days I put the 4x4 march in a setback (it moved like a meter) and then the reverse no longer worked.
If they can help me or guide me about what the fault could be, I would appreciate them very much.
Sincerely
