Motor Averia Seata Toledo 1.9 105CV of 2006
12 years 4 months before - 12 years 4 months before #40542 by manual-mecanica
Motor Fair Seata Toledo 1.9 105CV of 2006 published by Manual-Mecanica
When I put the makina, I get the fault to the flow. The K code is on the diagnostic machine is the P0102.
AGUEN COULD DCIRM K IS ?????
Thank you.
Latest edition: 12 years 4 months before by .
12 years 4 months before #40544 by manual-mecanica
Manual-Mecanica Response on the Saata Toledo 1.9 105CV Motor Fair of 2006
I am checking on other sides on the error and this is what I find of what refers to the error
I hope it helps you
2 Faults Found:
000258 - Mass Air Flow Sensor (G70): Signal Too Low
P0102 [/I] [/B] [/B] - 007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00000010
Fault Priority: 1
Fault Frequency: 2
Reset Counter: 242
Mileage: 0 km
Time Indication: 0
Failure: 000258 - P0102: Mass Air Flow Sensor (G70): Too low signal - SHORT TO LAND - INTERMITTENT
-LIST LIST THE FAILURE CODE 000258 IS THIS: 00258 - 0102. There is a zero and the letter "P" and marks another fault than yours.)
12 years 4 months before #40546 by manual-mecanica
Greetings
the
MAF sensor (more Air Flow) or air sensor of air
possible
solutions The Start with the Cheapst, Easiest Repair procedures: Verify that the mass air flow Wiring is connected properly and that there are no broken / Frayed Wires.
Inspect for Any Air Leaks Near The Maf Sensor.
Take the maf out and clean it using spray Cleaner Such as Brake Cleaner or Electrical Contact Cleaner. Be Gentle with the sensor.
Check The Voltage of the Maf Sensor (refer to Repair Manual for Vehicle Specific Information)
Replace The MAF Sensor
(Network Taken Information)
Please write correctly in Spanish
12 years 4 months before - 12 years 4 months before #40549 by manual-mecanica
Come on!! You are checking when writing well or consulting what problems there are most of what I put and paste to compare it with what appears to him (person who has the problem)
and what is the air luxury sensor ??????????
Greetings
12 years 4 months before #40572 by manual-mecanica
Thank you all x the dog responses and the problem is apparently a fuse of the fuse box, I check the Estabs Todso ok fuses but I did not realize one missing one but when I looked at it as I did not realize and I already had to erase the Code of Averi and it does not come to appear. The air flow sensor is the so -called flow this tine.
