Chevrolet Kalos cooling temperature sensor.
12 years 3 months before #40755 by manual-mecanica
Greetings to all, I am new here.
I have a failure in a Chevrolet Kalos, 1.4 16V 94 hp,
to which the release is not stable in cold, rises of revolutions, I think the problem is in the refrigerant temperature sensor, because in summer the failure is the setback the reverse is very low, you even get to,
I want to change said sensor but I do not find where it is, I have looked in the manuals published and I would not find its location. If someone can guide me in the location and change of this sensor.
12 years 1 month before #41632 by manual-mecanica
Manual-Mecanica response on the topic refrigerant temperature Chevrolet Kalos.
Friend the temperature sensors are mounted on the butt or in the body of water, specifically the kalos I have not seen, but they are always at hand, it is a sensor with a two cable connector if you put a photo you want to help you better.
12 years 1 month before #41646 by manual-mecanica
Thank you,
I have already found it under the admission collector, but to change it you have to get under the car, using an elevator, it is not in sight.
12 years 1 month before #41662 by manual-mecanica
ok thanks for letting us
