Hello, I would know someone like solving the following problem with my Toyota Hilux truck; In my Toyota Hilux once started and in relief I give the accelerated and do not answer me, and I turn on the chivato Check Motor, if I give the accelerator it does not respond to me and the engine goes out. That is all that happens to me and I don't know where to start the truth .. have if you can help me friends.
That light turns on when you have an electric motor breakdown, it is very widespread, the vehicle seem to be in the fault and does not rise. Connect a diagnosis machine in the OBD plug to know the failure you have or check 1 by 1 all the sensors and captors that the van carries. Anyway to get out of the way you will need a machine that erases the breakdown.
