Consultation of camshaft
12 years 3 months before #40828 by manual-mecanica
Consultation of the camshaft posted by Manual-Mecanica
I have a DR650 Suzuki motorcycle and I would like to know what advantages and disadvantages I would bring to increase camshafts.
Also that it would be necessary to do or take into account in doing so.
Thank you
12 years 3 months before #40830 by manual-mecanica
Manual-Mecanica response on the subject Consult the camshaft
No advantages that I know if anyone knows any to say it.
Disadvantages that the pistons stick in the valves, which do not reach the compression point optimal.
If what you are looking for is greater popcard, it reduces the cylinder head and reducing the compression camera the explosion will be greater.
If you help you click on thanks, that I do nothing but respond to everyone your problems and nobody thanks.
12 years 3 months before #40853 by manual-mecanica
Hi Walter.
The height of the tree cams are already calculated by the manufacturer for optimal engine performance, altering them would be to risk piston damage or valves as Igryo tells you and most likely that instead of getting power it is reduced, it better removes all the possible reduction in the intake air entry, if your problem is wear, it is better to change the camshaft.
Luck.
Miguel
12 years 2 months before #41042 by manual-mecanica
hello.
To gain power, acceleration, or better functioning at high or low regime, which "touched" the crossed arvol crossing.
that
to
say the time that the 2 valves remain open. I hope I have helped you hehe
if I have helped or clarified something click on thanks hehe
I am new in the forum and this is my first comment ... where to present?
all the best !!
12 years 2 months before #41055 by manual-mecanica
Actually, to enhance a vehicle and make it faster what I must improve is the Koran's relationship, since the effective torque is to floor and not in Dinam Valves to eliminate tension resistance, the crook is not very combined or useful if you do not put an admission cooler since it generates more temperature, and as it is obio and logical, the more temperature the lower the power and performance, the subject you mention is quite quite complex and there is a large range of modifications to perform, which generate many discussions because it does not always Turbo or a super charger, the interculler radiator or enlarge the radiator, get gear gears after or cut secondary axis and number of things, if you tell us that vehicle is and that it is what you want to get is easier to help you, luck.
