Hyundai H100, temperature indicator.
12 years 3 months before - 12 years 3 months before #40881 by manual-mecanica
Hyundai H100, temperature indicator. Posted by manual-mecanica
How, I have a H100 H100 of 15 passengers of the year 97 Diesel. We try to keep it in optimal conditions since it is collegial transport. I will try to be brief.
We currently detect that the temperature indicator rises (medium temperature) once we activate the front lights (night lanterns) or when activating the air conditioning, when both loads and air conditioning are activated the temperature passes to 3/4. Turns up both loads the temperature that in the normal 1/4.
To try to find the fault we install new battery terminals, new fuses in the box attached to the positive terminal, new relay of main lights, change of socket for the h4 alogens, cleaning of the fuse boxes with electronic contact Cleaner, change of the alternator belt.
After these corrections and for a moment I thought I was the problem but still continues.
The load measured in the battery terminals with the engine running and lighting lights is 14.0 v. But when I turn on air conditioning the voltage is 13.5
would add any recommendation.
Thanks a thousand.
AAAG.
Latest edition: 12 years 3 months before by .
11 years 9 months before #43114 by manual-mecanica
Manual-Mecanica response on the Hyundai H100 topic, temperature indicator.
I have the same problem.
