Vortec 5.7 Distributor Failure
12 years 3 months before #40890 by manual-mecanica
Failure in Vortec 5.7 Distributor published by Manual-Mecanica
I have a problem with a suburban99 Vortec 5.7 What happens is that in the distributor's lid does not come out spark in the posts 2y8 I already changed the cover, rotor, spark plugs, chain and chain gears
12 years 2 months before #41180 by manual-mecanica
Manual-Mecanica response on the topic in Vortec 5.7 Distributor
I do not know if the problem has already been solved but if not, check the wear of the distributor of the distributor that these on occasions are wearing and baria the arrow a lot, although most likely it is that the lid even if it is a new steb failing I recommend that you try an original lid or one that you are sure that it does not fail. out
