Greetings friends and I apologize for responding just, with the truck everything was like this: this truck over-heated and took her to her mechanic dragging because she no longer lit, they changed the boards of the heads and when giving her she started with the problem and took me to correct the problem, the truck when giving her marches fast, it is only the problem that there are 3 coils that do not work. Injectors if there are pulsations, and in the battery side coils only work the 1 and receives their pulsations and coils 2 and 3 do not work because they do not receive pulsations, and from the driver's side only coils 5 and 6 work, and coil 4 does not work since it does not receive pulsations, the problem is presented both in cold and hot, my doubt is if the problem could be the problem. Cylinders could be that they forced the engine and overcome it and if it was so the client will never say anything for not knowing.
