Nissan Frontier problem
12 years 2 months before #41056 by manual-mecanica
Manual-Mecanica Answer on the problem Nissan Frontier
It is difficult but not impossible, most vehicles do not pass through the computer the theme of the spark, this is separate by means of a magnet or sensor, but if you want to get out of doubt you have a scanner and this will accuse you of a unit of command if it has a failure, when a vehicle is heated a lot it is normal for some feeling sensors, such as the temperature or anyone that is directly in the butt or block, you have the scam to leave the doubt.
