My Nissan truck helps with a lot of smoke
12 years 2 months before #41051 by manual-mecanica
My Nissan truck helps with a lot of smoke published by Manual-Mecanica
I have a Nissan 1989 Motor 1800 truck which did not throw smoke his head 3 times because he started to smoke and after that he throws me a lot of white smoke and when he accelerated he throws a lot of smoke and check him compression and empty and apparently they are fine. I have been reading on the Internet and apparently the EGR or PCV valve
12 years 2 months before #41059 by manual-mecanica
Manual-Mecanica response on the subject helps my Nissan truck with a lot of smoke
Petroleum or Displaced? Heats has water consumption Fujias oxidized more data to be able to help you better, because so it can be from a cracked cylinder head to problems with the motor block.
12 years 2 months before #41068 by manual-mecanica
The truck does not heat up well on but what I have seen is that the spark plugs are filled with oil and of course after one day it starts to tremble and I have to clean them again. Before removing the cylinder head, the spark plugs were fine without a trace of oil and almost didn't smoke just a little sometimes.
12 years 2 months before #41087 by manual-mecanica
Check the distribution that is well regulated
