Seat Ibiza starter [solved]
12 years 4 months before #41150 by manual-mecanica
Manual-Mecanica response on the Seat Ibiza starter
A note that I add: if the battery is very bad and you try to start with tweezers to another battery does not start because the current is distributed, one part goes to the bad battery and another part goes to the vehicle.
It has happened to put a car going by giving it current and yet costing to start, put it new as Kikemec tells you.
12 years 4 months before #41184 by manual-mecanica
I have changed the battery and the car to push I can start it but with the key no! Does it follow the same problem that could do more? It is that I do not even do.
greetings!!
12 years 4 months before #41186 by manual-mecanica
Hi Mikel_123. Why do you say the problem may be that the engine does not have a good grounding with the chassis or that you have a problem with the cables that reach you to start.
First I would try to put a good cable connecting between the engine and the chassis, if so the problem still persists; also check that you have a good connection between the battery and the start and then I would try to put direct current to the start of the start, if so it goes it is that you have any problem in the line that goes between the anti -theft to the start.
Hoping this to be there in something.
All the best.
12 years 4 months before #41188 by manual-mecanica
I have a light hehehe, that vehicle has iron fuchibles on the battery?
They are like flat sheet. On one occasion and after dizzy I spend a lot with a Cordoba that had one of those sheets from 110 to half broken and did not start me.
12 years 4 months before #41189 by manual-mecanica
Jose.p I will try to give him a good dough and see what happens and running and 30 direct battery and 50 also had that to see what happens hahaha.
Igryo the fuses you say because it does not sound to see me seen but I will look good to see if you have them.
Thank you very much for your help! Let's see if I can already hahaha and I'll tell you how it is doing.
Greetings!!
