Nissan Terrano II
12 years 2 months before #41170 by manual-mecanica
Nissan Terrano II published by Manual-Mecanica
hello! I have a Nissan Terrano II of the year 2003, he has a small problem, in the morning it costs him a lot to start, it is as if the diesel did not reach him, he still took him a workshop and he told me that it was the drums, I insis It can be the diesel pump that does not work well, I would like to save buestra opinion, and where I can get a workshop manual of Nissan Terrano II (2003), if it is the diesel pump, you can tell me where it is since I do not see it. Thanks a greeting.
12 years 2 months before #41183 by manual-mecanica
Manual-Mecanica Response Nissan Terrano II topic
If you could say what type of motor you have to help you
12 years 2 months before #41187 by manual-mecanica
I do not know what engine you have but if it is the one I think the engine is looking at the inmedy chain to the left. The chain housing covers it but if you look on the right side of the vehicle at medium height you will see the pump.
What I would do: Gasoil's entrance to the pump put a transparent sleeve and the next day I would tell someone to tear it out and you look if there are air bubbles in the sleeve that will tell you if the pump is discharged and you can discard if it is fuel before disassembling.
12 years 2 months before #41190 by manual-mecanica
Hello! The engine it carries is the 2.7 TDI of 125 hp.
Thanks for the answers, I will try the transparent sleeve, if it has bubbles it means that the pump does not retain the diesel, not retaining the diesel is the reason not to start? The pump would have to be changed, or it has repair.
12 years 2 months before #41191 by manual-mecanica
The engine does not carry a distribution chain or strap, it goes through pinions. 2.7 TDI 125 hp.
