I need help with a Blazer 96
12 years 2 months before #41202 by manual-mecanica
I need help with a 96 blazer posted by manual-mecanica
The problem is that the truck does not start, I already changed the gas pump, and nothing is done directly and starts only what ends what I miss, I already scanned and marks anything, I feel how if I will inject gasoline, it is a 4.3 vortec engine I hope they help me,
12 years 2 months before #41204 by manual-mecanica
Manual-Mecanica Answer on the subject I need help with a Blazer 96
Hello, you can be a bit clearer in the diagnosis you have of the truck you did.
11 years 10 months before #42918 by manual-mecanica
I want to know the hubication of the gasoline pump.
It is failing and I want to make the repair myself.
11 years 10 months before #42921 by manual-mecanica
First you have to check the preservation of the gasoline pump, the vortek engine works with a pressure from
55 to 60 pounds if the gasoline pump does not give you this press The negatibas Ke signals reach the injectors above the engine brings a square connector that AI is where the signs are tested friend friend
