Chrysler Pilot Oil
12 years 2 months before #41210 by manual-mecanica
Chrysler Pilot Oil Published by Manual-Mecanica
Good to all, my problem is that when I under strong slopes I am lighting oil witness someone can explain to me because it is a stratus of the 2000 imported gasoline without changing distribution strap, 106750 kms thanks in advance.
12 years 2 months before #41213 by manual-mecanica
Manual-Mecanica response on the topic Chrysler Pilot Oil
Normal, the pump stops sucking oil through the inclination and lowers the pressure so it marks you. Look that the oil level is in the maximum mark (with the cold engine).
And be careful that if you leave without pressure to the car you can burn the engine.
12 years 2 months before #41234 by manual-mecanica
Thank you very much I will look at the oil today : UNSURE:
