I need urgent help
12 years 2 months before #41246 by manual-mecanica
Manual-Mecanica response on the subject I need urgent help
Hello, as a comment, you already check that the gasoline pump arrives current. Or also check the land that has it in the middle of the chassis without that land does not start the pump and Czech that has a pressure of 70 pounds but does not start, I hope it helps you luck ....
12 years 2 months before #41248 by manual-mecanica
If the bonba works.
12 years 2 months before #41262 by manual-mecanica
You already checked that the injector serves since it can have a current but it cannot serve and something else you can do is start it with buoy and put a pressure of 72 pounds the inyentor may take off if it is that it was stuck lucky
12 years 2 months before #41264 by manual-mecanica
I'm going to put the buoy as you tell me I hope that is that ... a comment ... it is not a single injector has 6. but I am going to do it and I will inform you ... thanks x your time
12 years 2 months before #41276 by manual-mecanica
The ideal is to reduce the search field, Czech that is missing, fuel or compression, Martinez is right if there is a pulse but does not inject the injectors can be in cut, but Czech spark in spark plugs and everything.
