Attitude Band Tensioner 2008 DOHC 1.4
12 years 2 months before #41267 by manual-mecanica
Attitude Band Tensioner 2008 DOHC 1.4 Published by Manual-Mecanica
The problem is that it was lost, the spring of the tensioner of the band of time, which paper plays the spring that was lost or function of it.
12 years 2 months before #41275 by manual-mecanica
Manual-Mecanica response on the Time Band tensioner ATTITUDE 2008 DOHC 1.4
Is that small spring that goes from a bolt to a hole in the body of the tensioner bearing? Well in general, these tensioning springs are to tighten quickly, if you do it by hand and tense and then tighten the bolt or nut of the bearing you will not have problems.
