Opel Vectra 1.8 1993 Ignition problems
12 years 2 months before #41319 by manual-mecanica
Friends, I have a problem with an Opel Vectra 1.8 of 93 '...
it happens that the car was without problems, from one moment to another the engine was stopped and no more turns on. When checking it, I saw that only current arrives at the 1 and 4. Spark plug cable. Discussing the topic with a friend, we decided to change the distributor and rotor lid but the car is still the same. The coil does not present problems ... I do not have much technology to check the engine, so he consults you that can be.
Thanking in advance.
Felipe
12 years 2 months before #41369 by manual-mecanica
Manual-Mecanica response on the topic Opel Vectra 1.8 1993 Ignition problems
Good compete, I am obviously missing the high cables. greetings.
12 years 2 months before #41370 by manual-mecanica
None of that compa, I lifted the valve lid and found the cut camshaft ... very rare, but I changed it and is working wonders ... greetings and thanks for the time.
12 years 2 months before #41385 by manual-mecanica
hahahaha is not as rare as you think that happens a lot in those engines, and turns very little or does not turn depend on how it is cut since height,
