Nissan Micra 2005 problem does not start
12 years 3 months before #41332 by manual-mecanica
P1611 code problem, it: blush: is the NATS, someone knows how to
solve them
12 years 3 months before #41333 by manual-mecanica
Manual-Mecanica response on the problem Nissan Micra 2005 does not start
The NATS is the Nissan Immobilizer System Torra codes and encodes key and if you can not lead it to be diagnosed to take out that fault code for that reason it does not start
12 years 3 months before #41334 by manual-mecanica
You have to have a chip in the key and a transfers in the starting bombin. If the key is a new copy you need Nisan to put the chip in the key and if the failure is in the car, look that the transfers is good, but I doubt that it is broken because the only thing it does is send the signal to the switchboard and the switchboard recognizes and lets you start.
If I try to start with a key that fell the chip or copy without a chip or I have a bridge it is blocked and it is time to go to Nisan to erase or do not know if reflex (diagnostic machine carries option) Bertone if I carry I think.
12 years 3 months before #41342 by manual-mecanica
I will try what you say to see what happens. But it will be on Monday, and I commented to see what happens, if anyone knows the truquito so as not to take it to the Nissan, I appreciate them ok fats.
12 years 3 months before #41391 by manual-mecanica
Since I apparently it was a 5 -door suich
I was grabbing that the nats was activated at these moments I put it to the test you will take two without the failure just disconnect it thanks for their comments if I fail ay they commented: Woohoo:
