I fit it as you say, the turn in the direction of the clock needles, I have not done it, but on the contrary "that I do not know if that is important but I wish" everything else and I take except the turn you comment in a clockwise direction.
And observed that the part that does not have a tensioner from the crankshaft to the camshaft as the belt is missing a pelin to tighten better, is that symptom of bad adjustment of the tensioner, right? Come on, I don't have it well.
I have tried to see something in videos and use a belt tensioner is it necessary too?
I am already giving up the head without being successful, the self -destination says on the tensor theme:
-Get the tensioning roller until the index is indicated 9 "no sense of turn" "good in a schedule".
Mount tensor fastening tool "a L -shaped ring"
-Preate the tensioner nut.
-Get the crankshaft 4 turns and put it in the draft position.
-Comprob that adjustment pins enter and take them out.
- Hold the tensioner with the Allen key, loosen the nut, remove the ring.
-Get the tensioner roller until the index is in the indicated position 12 "helping me of the Allen clear."
-And if you pass from the notch to repeat the tensioned? Everything from tightening first "I have made it, although that, I don't know how such"
"There is something that escapes, is it complex to perform with little experience in these tensioners?"
As always a health and thank you very much.
