Brake light switch
12 years 1 month before #41527 by manual-mecanica
Brake light switch published by Manual-Mecanica
HLA good I wanted to know how you can check the status of the brake light switch, which is located on the brake pedal ... I hope your answer ... thanks in advance
12 years 1 month before #41536 by manual-mecanica
Manual-Mecanica Response on the topic brake light switch
Put a multitester or a tester in the continuity function, put a tip of the tester in one of the terminals and the other in the other, the tester should mark you 0 or infinite, unde the button and deveria mark continuity, here a detail there are brake bulbs that work in the speed, but the check is the same, do not forget that there is a brake fuse that is cut.
