Corsa electronic injection problem
12 years 1 month before #41654 by manual-mecanica
Corsa Electronic Injection Problem Published by Manual-Mecanica
Hello, to see if someone can help me, my car presents the problem that all the indicators of my board are lately walking as if they are disconnected and they are already several times that when trying to turn on it does not turn on since it does not reach current, it only turns on the indication of the anomaly in electronic ignition, this will be a false that has the electronic wiring or it will be the computer as it is indicated as it is indicated to which it will take it to me as it will take it to which it will take it to me as it will be Check it?
12 years 1 month before #41656 by manual-mecanica
Manual-Mecanica response on the problem in the electronic injection of Corsa
Hello very wenas
, the alternator may be possible cause
12 years 1 month before #41660 by manual-mecanica
Hello partner, the problem of your car is in the ground poles of the ECU or battery. Revisa two masses that it carries in the butt next to the multiple of admission near the camshaft pinion and also the mass of battery to the chassis. I hope this data helps you salu2
12 years 1 month before #41663 by manual-mecanica
Hello, the first thing you have to check it is where you have current if your system has a chip in the ignition key, your module is being deprogramming I hope the information is served manual is from otromodello but it is the same system I hope it serves you
12 years 1 month before #41664 by manual-mecanica
Hello, the first thing you have to check it is where you have current if your system has chip in the ignition key may be your module being deprogramming I hope the information serves you
