Change Heater Renault Express 1.9
12 years 1 month before #41679 by manual-mecanica
Change Heater Renault Express 1.9 Published by Manual-Mecanica
Hello good morning, I have acquired a Renault Express 1.9dy, it is hard for you to start in the mornings have changed two heaters but there are two of difficult access, do you have to disassemble the diesel pump? or there are some truquillo to ssacarlos.
12 years 1 month before #41684 by manual-mecanica
Manual-Mecanica Response on the topic Change HEATERS RENAULT EXPRESS 1.9
as???? On Friday, the heater changes to a Renault Clio Motor 1.9D carries the same engine that expresses it and I don't get problems. If you can put a photo to see what you mean is appreciated.
12 years 1 month before #41687 by manual-mecanica
Thank you very much for the speed of answering, the problem I see is that the two heaters who are on the side of the distribution belt would play in the pump, attached photo to see better, the same is not very skilled.
thank you so much.
12 years 1 month before #41692 by manual-mecanica
: Woohoo: That engine was never the case but if you take them out and do not come out if you look like you have the pump.
Well you tell us how it has gone or if anyone knows how to save the pump that tells us.
12 years 1 month before #41731 by manual-mecanica
Good morning
I have an equal van and you don't have to get the bomb, it's just morning
greetings
