Hello old man, look independent of the vehicle branch of libricacion is large but let's observe your problem, the oil pressure system can be good but I recommend that you place a bronze t in the oil bulb in the part of the block which will allow you You find it in any business and know the exact pressure, in the event that the clock marks bad pressure or deficient you must replace the oil pump from otherwise let's go ahead, remove the valve cover and take rocker axis with its rockers respectively and proceed to remove the acite filter. At the base of the oil filter and motor oil in a clean container to reuse it, where it is screwed there is a plug where it can be exagonal or parker that you must remove an eye that this plug is a pressure valve when the withdraws will come out a spring and a steel ball when this is outside with a motor wash gun with diesel you must blow with the compressor all the compressor That it has the base of the rocker axis and the diesel must leave or escape pressure on that plug since you should know that the lubrication ducts can be open or closed are open in the case of the rockers where the oil drizzle lubricates them without problems and are closed in the case of the crankshaft which forces to take a pressure in the gallery of the lubrication tree of lubrication. Lubrication in Aguna Part is broken a seal packaging or the oil pump supiono dirt that formed a plug in a duct and with the compressor should leave.
Friend if this does not work for you, you should not adjust it only buy a packing set and stamps and already (whenever the oil pressure accompanies you ...
Greetings Mannn to find you ...
