Battery
12 years 1 month before #41716 by manual-mecanica
Battery published by Manual-Mecanica
Hello friends. I have a DAF 400 3500T van
I have changed the battery thinking that that's why I didn't start me, (by putting the tweezers if it started) and nothing also seems as if the entire load of the battery had sucked in a moment.
What can happen to you?
Thanks and greetings.
12 years 1 month before #41719 by manual-mecanica
Manual-Mecanica Answer on the Bateria
Well look at Isma your problem can be in the regulator of your alternator that is activated or some short circuit in your van's electrical system
12 years 1 month before - 12 years 1 month before #41720 by manual-mecanica
mass!!! When did you get tweezers the negative VAT to the block or chassis? Look to see if the negative does not make a dough to chassis.
You will have when the dough of chassis is bad you have a little current but it does not reach you to start.
Latest edition: 12 years 1 month before by .
12 years 1 month before #41758 by manual-mecanica
Also Czech the most obio of everything that one never gives importance, the terminals and tightened them wants to isolate themselves
12 years 1 month before #41765 by manual-mecanica
Thank you guys effectively with the terminals and everything worked again. Thank you very much for the help.
