Ford Transit 2.5 TDI 1995
12 years 1 month before #41755 by manual-mecanica
Ford Transit 2.5 TDI 1995 Published by Manual-Mecanica
I have ignition problems,
12 years 1 month before #41756 by manual-mecanica
Manual-Mecanica Response on the Ford Transit 2.5 TDI 1995
Which is the problem, it takes to start in cold, the donkey turns slow? If it takes cold, they can be the burned heating spark plugs all or some, but specify more your consultation. :(
12 years 1 month before #41757 by manual-mecanica
It is very difficult to give you a diagnosis
you can put the vehicle data specifications
and the failure where it comes when it makes it in hot cold if it makes noise if it humans if it loses liquid
you can attach photos and videos
Ezzate
12 years 1 month before #41763 by manual-mecanica
I see that the ignition surge fails, the heating spark plugs are fine
12 years 1 month before #41764 by manual-mecanica
It is cold, I already put the data and specifications, the ignition reray fault, I have to look better
