Hello, I am fixing the cylinder head of my Opel Corsa 1700 Diesel Motor Isuzu Xi7D and when I do not have the workshop manual I do not find how to empty the radiator because I have the water circuit full of oil to see if you can help me thanks and greetings
vacate with the radiator sleeve and blowing with air if you find it but even if you clean it well will always climb the glass of Spanish .. the problem is that oil was passed to the water? because some opel carry a water radiator oil and usually leave a lot
Eye with that theme of the oil in the water the heat exchangers in the franses do the same and the problem is not in the cylinder head, the best way to clean is to disconnect the two hoses of the radiator and let run a lot of a while and yet everything will be removed.
